1
- #1
I've been asked to determine the capacity of some homemade sawhorses we have in the shop. These are made of carbon steel HSS sections. I was wondering if anyone knows what manufacturers of commercial sawhorses do for the following:
1) Safety factor
2) Impact factor (if any)
3) How load applied? Concentrated, uniform?
4) Where load applied? Even though a concentrated load at the center would seem to be the worst case, I can imagine a case where a concentrated load at the very end would control because of web failure doing a check per AISC 14th ed., section J10.
5) Deflection of supported load. Imagine two sawhorses supporting a bundle of rebar. The rebar sags significantly. In my case, the top horizontal member is a tube (HSS). Because of this sag, instead of each vertical wall of the tube carrying the load evenly, the inside wall (wall closest to cg of rebar bundle) would carry most or even all of the load.
1) Safety factor
