scale model
reotex
Automotive
Nov 27, 2004
like to make an automotive scale model as starter for real production, what is a good scale to use, 1/4th 1/3th ??
Depends what you want it for. Our stylists often use 1/5 scale , as do the aerodynamicists.
For packaging and so on we use 1:1 so we can use slave and carry-over parts.
Cheers
Greg Locock
1/5 is good for me, its indeed for the aerodynamics, in this case a 3 meter long closed twin axle trailer, many thanks your info.
With a 3 metre long model you'll need a 'full size' (in car terms) wind tunnel, although you may get away with a half size one if the test section is long enough.
Check with your wind tunnel for the maximum size models they can accept!
Cheers
Greg Locock
