SteelPE
- Mar 9, 2006
- 2,759
We are currently working on a wood framed building with scissor trusses. We are responsible for the design of the structure as a whole and a wood truss manufacturer is responsible for the design of the scissor trusses. Code is IBC 2015. The spans of the scissor trusses are quite long (40'-0").
When speaking to the truss manufacturer with regards to the design of the connection of the truss to the top of our wood walls we are being told to use a Simpson TC26 (diagram attached). We have some concern with regards to this connector as we are requiring the truss to provide stability at the top of the wood wall.... and if the connection is allowed to slide then we will lose that stability.
Is it common for wood framed buildings that use scissor trusses to use this type of connector (Simpson TC26) and just ignore the stability concern.... or do you use a different connector that inhibits lateral movement of the truss?
The truss manufacturer has not been helpful at all with this project to the point of being combative. They are basically saying that it's up to us to solve this issue and they do not want to change their design around. It is not making for an easy project
