I'm designing a screw feeder's hopper, where I need to work out what type of force arises when the screw is operating.
Assuming there's an axial force developed in the screw shaft. Is there a manual/ guide that helps me work out these reactions:
- From the screw shaft onto the hopper. The screw assembly is supported entirely by the hopper structure.
- From the conveyed material (pull out) acting on the hopper's wall at the outlet?
Cheers
Cheers
