lahori
Chemical
- Mar 22, 2019
- 10
I am working on a Dry Gas Seal Project for Centrifugal compressor. I have a book on Compressor Dry Gas Seal In which following is written
"It is also desirable to minimize seal gas consumption. The majority of
the injected seal gas flows across the inner labyrinth seal and back into the
compressor (i.e., the flow is recycled), and very little flow is actually required
for the gas seal. This recycled flow into the compressor is inefficient and uses
more energy at a cost to the user"
Now here he is referring to after passing through inner labyrinth seal and back into the compressor (i.e, the flow is recycled). I cannot understand this one. In my understanding once seal gas is injected it flows through primary seal( where it ac as working fluid for mating and stationary ring) and then goes to primary vent.
I am still very new to Dry Gas Seal System so may be I still do not have full grasp of the topic. Please help me out here.
Yasir
Yasir
