We were testing a dual - tandem metal bellows seals (rotating seal heads) on a vertical pump..the outboard seal has a pumping ring for the plan 53B barrier fluid..we had injected the barrier into the seal at the location of 2 O'Clock and piped up the barrier out at 12 O'clock..the seal squealed a lot..and then we switched the piping around and the seal stopped sqealing..we did this twice and the same thing happened..whats the logic behind this?
