Rwelagedara
- Dec 7, 2016
- 11
Hi Guys,
Please guide me for the following.
We are to provide neutral voltage displacement protection in a solar power plant. For this, a 3 phase protection VT is utilized.Primary winding of the VT is connected to 33kV lines in the power system.Primary winding is star connected and neutral is grounded. The secondary winding is connected as open delta and this open delta terminals will be connected to the protection relay. Attached sketch shows the connections.
However, as per our undestanding , we should connect one terminal of open delta to ground(ground connection shown in red in the attachment) when connecting to relay terminals, in order to provide a reference to the relay. Is it correct to connect one open delta terminal to ground, since it seems like a line to ground short circuit when looking at the VT.Can a relay operate without connecting one terminal to ground?Will there be an issue to 3 phase VT with this connection?
Please advice.
Please advice.
