Hi All,
We have to revisit the seismic design of some older flat bottom tanks.
Initial assessment is that the tanks themselves won’t be able to resist the seismic loads. They are built on crushed stone/sand pads, are not anchored, and have a diameter-to-height-ratio of less then 2.
Our legislation, however, requires only primary or secondary containment to be able to resist seismic loads and stay leak tight.
Secondary containment contains of a subgrade clay liner and earthen dikes with clay cores.
I’m wondering if you can demonstrate the seismic performance of this kind of construction?
Before we start putting resources to the task I wanted to ask if you know if this has been successfully done before and maybe have some references/contacts for this?
Kind regards
Kind regards
