The question is related to section 906.1 of IBC. The section clearly defines 6 locations (under item 1 through 6, apart from table 906.1) where the fire extinguishers are required. The confusion is in exception of item 1 where it says "Exception: In Group R-2 occupancies, portable fire extinguishers shall be required only in locations specified in Items 2 through 6 where each dwelling unit is provided with a portable fire extinguisher having a minimum rating of 1-A:10-B:C.".
The question is How Group R-2 requirement is different than other occupancies when the exception is asking to follow locations mentioned in items 2 through 6 which is also applicable for other occupancies? Is the only difference for Group R-2 is related to rating of extinguisher or Is there something I am missing? Looking forward to understand from experts.
