  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
section view
tazengr
34
I am making a detailed or drawing with dimensions in wildfire 3.0.
I inserted a front view by using
Insert --> Drawing View --> General.
Now I would like to project a section view across the centerline and place it below this view.
Does anyone know how to do that?
I would suggest that you check out the help files in Wildfire....they're pretty good for the simple stuff.
Views > Add View > View Type
To Create a Partial or Broken View with Local Cross Sections
1. From the VIEW TYPE menu, choose Partial View or Broken View.
2. Choose Section > Done > Local.
Note: Local is not available for half views. It is available only if you choose Full View or Partial View from the VIEW TYPE menu.
3. Select a center point for the view and orient the view as desired.
4. Create or retrieve a cross section for a local cross section to reference. Use commands in the XSEC ENTER menu.
5. Select a view for arrows or press the middle mouse button for none.
6. Do one of the following:
? If you are creating a partial view, select a center point for the partial view, sketch a spline defining partial view boundaries, and select a center point for a breakout. To create more local cross sections, specify a cross section to reference and then define the center and boundaries of the breakout. Choose VIEW BNDRY > Done.
? If you are creating a broken view, select a center point for the breakout and follow Steps 7 and 8.
7. Add breaks by selecting reference points and choose
ADD/DEL BRK > Done.
8. Select lines to share the same spline; then sketch a spline.
9. Choose EXIT > Done.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
