Section View
Finglas
137
Is it possible to creat a section viiw around the highlighted area in this isometric drawing?
If I understand what you are looking for, you may want to check out the first reply in the below thread - it shows a video of using "break out section" in a way that may be similar to what you want - in your case use the circle in the same way that the video is using the rectangle to make the cut.
