Section VIII Division 1 - Table UW-12 3
IdanPV
445
Hello all.
I have a question and I didn't find any answer here or in the Code interpretations website.
I am dealing with longitudinal joint in a vessel with diameter of 500mm, thickness is 3mm.
No Radiography is made.
Is it permissible to use a joint efficiency of E=0.6 for this kind of welded joint although it shall be classified as Type No. (1) joint?
Thank you very much
I suppose it's possible, but why would you use an efficiency lower than permitted?
SnTMan,
Thanks for your comment.
Do you have any refernce which stated that it is permissible?
The thing is someone made a mistake with the U-1A a lot of MDRs were fill as can be seen in this picture:
Now, the A.I asks to change the U-1A and I wanted to check if there are some interpretation or paragraph which allows me to leave it that way.
Per ASME Code, the vessel can be made with the joint eff of 0.6. However, is it complied with the the Client Standard?
If it was only a typo on the U-1A, why not to have the Fabricator to correct it?
Very confused.
[ul]
[li]In your initial posting you said this was a Type 1 joint, but in your picture of the U-1A it's a Type 3 joint.[/li]
[li]A Type 3 joint has E=0.60, but it's only permitted on certain circumferential welds, and you've indicated this is a longitudinal weld.[/li]
[/ul]
I guess my one comment is that you can only know if E=0.60 is correct or a typo by reviewing the design calculations to see what was used. Without the calcs it's just guessing. If the U-1A is wrong, the fabricator should correct it.
Why would you want to leave it that way? It should have never been signed with a type 3 joint. Either your vessel doesn't comply with the Code or your data report doesn't. Non-Conformance the data report and sign a new one....and be happy your AI doesn't scrap the vessel. How are you proving it is a Type I?
Hello all,
Thank you all for your comments.
The MDRs will be corrected.
I agree that you should fix the error, so that the MDR matches the calculations, but to answer the original question: Yes you can use a lower value of efficiency in your design. See UW-12(a),(b), and (c). They all begin with the words "A value of E not greater than that given in column... of Table UW-12 shall be used in the design calculations..."
For a joint with no radiography, UW-12(c) would apply.
