Thank you in advance.
I am using Premium 2018 X64, Sp3.0. {Window 10 Pro, 64GB Ram, 64 bit Operating I7-7700CPU @ 4.20GHz}
With regards to sectioning a large assembly in a drawing. The Assembly in question is about 64MB and contains approx 20,000 parts. All Speedpaks are turned off, since I know you can not section anything (it seems) with Speedpaks on.
When I TRY and do a section it just (after 1-1/2 hours) does not want to create a section. Is there a setting in Solidworks that maybe I can adjust? I tried maybe adding a CUT feature in the assembly. BUT Solidworks will NOT allow me to create a cut thru this many parts.
Very frustrated with this...
ADVICE??
ADVICE??
