Sectioning
drbauer
5
Can Anyone give me a quick ref to the standard for NOT sectioning shafts and screws on a drawing
ASME Y14.3-2003:
4.3 Nonsectioned Items in the Cutting Plane
4.3.1 Sectioning Assembled Items. When the cutting
plane lies along the longitudinal axis of items, such as
shafts, bolts, nuts, rods, rivets, keys, pins, screws, ball
or roller bearings, gear teeth, spokes, and the like, these
parts are not sectioned except when internal construction
is shown. See Fig. 47.
4.3.2 Conventional Section Lining of View. Where the
cutting plane is perpendicular, or cuts across the items
in para. 4.3.1, the sectional view is section lined in the
usual manner.
Ben Loosli
Sr IS Technologist
L-3 Communications
The one and only one that comes to mind is that if it is an industry standard you only have to callout the General info of the screw.....(UNC-30-.25) Can't exactly remember how it goes. (be in civil to long)
Namdac
namdac,
You are correct, but the thread is about sectioning.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
The screw thread issue came up in thread1103-159528
ASME Y14.6-2001 para 3.2 addresses the issue of whether to reference the thread standard.
In the US the name and number of the controlling thread standard is frequently omitted from the drawing. Reference is made instead to the designation symbols of the standard, such as series symbols and class symbols. To avoid misunderstanding, it is recommended that the controlling organization and thread standard be specified or otherwise referenced on the drawing.
It then gives examples of the thread spec as part of the callout.
But as Ctopher says this is a bit off topic.
Multi and Secional View Drawings ASME/ANSI Y14.3
Section 3-4.3.1 - Where the cutting plane lies along the longitudinal axis of items such as shafts, bolts, nuts, rods, rivets, keys, pins, screws, ball or roller bearings, gear teeth, spokes and the like, these parts are not sectioned except where internal construction must be shown.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
