Hi All,
Just trying to create a drawing view whereby some parts of the component are sectioned where as the rest are not. I will try and explain as this isn't as straight forward as it sounds!
I want to section down a shaft so that the gears are sectioned, however all other parts need to be fully view-able. If i use the section tool and choose the parts that i don't want sectioned it works to some degree but then some components are then 'hidden' due to where the section line is. is it possible to section just a couple components by arrangements?
James
James
