In SW PART (not assembly and not drawing).
I am trying to find out if there is a way to see, all at once, all of your hidden elements (line, curve, surfs) that go hidden as you go along doing your design.
I am coming from CATIA where you can easily toggle between work area and hidden area (show/no show) and see, along with the tree, just what was used in the process of creating the final part.
Not seeing a way to do this in SW.
I know you can pick one item at a time in tree and hide / show it, but this just isn’t practical if you are dealing with a file that has hundreds of commands in the tree and you need to go back and do an edit. You could waste hours. I’m hoping the core to editing in SW is not Hide and Seek.
Thank you in advance to anyone who can provide any help on this issue.
