All,
I want to first point out that I understand the rules about not using conductors that are higher rated than the terminal lugs or other circuit devices. My question is not about applying the rule. It is in regards to why this rule exists as it does.
It would be logical to say that if I have a breaker rated at 75C that I cannot use a 60C conductor on that breaker because the conductor is rated lower than the breaker. But that is not what the rule says. The rule says that I cannot use a 90C rated conductor on a 75C breaker terminal, even though that conductor is rated at a higher temperature than the breaker.
It seems backwards. Can anyone explain why it's there and what's being protected?
