Guest102023
Materials
Hi all,
I'm being pushed to build my own home met lab by sharply rising costs and increasing turnaround times of the labs I occasionally use. Most of my work involves carbon steel, often with welds, to support my failure investigations. Nothing that requires specialized tools or techniques.
I am looking for low-priced sources, used or new, for the following:
[ol 1]
[li]- Metallograph with digital camera. I don't require anything fancy like imaging software or even a live link to a monitor. Just a small consumer-sized camera sitting on top of the eyepiece tube.[/li]
[li]- Vickers microindentation hardness tester. 1,000g maximum load but I’ll settle for 500g.[/li]
[/ol]
I already have most of the grinding and polishing necessities including a mounting press (thanks to a lab clear-out at the local community college). I have a machine shop partner for breaking down the big samples.
I've set a budget of C$3,000, which is the cost of two to three small lab subcontracts. I'm happier to buy used Western-made equipment than new Eastern stuff, even though it might cost more.
Any and all suggestions are welcomed. One limitation is the essentially closed US/Canada border, making importation more expensive than pre-Covid.
Thanks in advance.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
[ol 1]
[/ol]
Thanks in advance.
