seepage analysis on geostudio seep/w
careka
PT
Hello good fellows!
I am doing a research over a seepage through an embankment dam.
I am new to geostudio seep/w and I need to do a comparison analysis considering no flow on the unsaturated zone vs flow on both sat/unsaturated zones.
The only way I figured to do this is to steeper VWC function but there is always flow, even if less.
Is there a way to consider abs no flow over phreatic surface in this software?
Thank you in advance,
Careka
You must create a 'Steady State Condition' to begin with. Flow may be very slow, but is still flow. This is the 'real world condition' in near surface geology and man-made earth structures.
I'd consider using visual mudflow. We think of numerical flow models in the plan dimension. However, you can also make a numerical model of a vertical slice and you can assign the properties for each block of the mesh. With proper boundary conditions, the model will solve the flow conditions.
This works. . . if you have Visual Modflow.
f-d
ípapß gordo ainÆt no madre flaca!
emmgjld
Yes, I am in a steady-state analysis. As in my briefing, I've already understood the minimum flow...
In this situation, how would you advise me if I was to compare the flow quantity between taking into account the only the flow under phreatic vs real flow?
fattdad
Thank you for suggestion but I am realy into seep/w
Thank you both
