ReverenceEng
- Feb 18, 2016
- 81
Easy question (I hope).
I have some equipment that is being mounted to the floor, walls, and ceiling of a concrete tunnel (all four sides) that goes under a tarmac. Think: typical walkway that connects terminals underneath the tarmac.
I would normally use the SEISMIC DEMANDS ON NONSTRUCTURAL COMPONENTS PER CHAPTER 13 of ASCE 7-10, of which the ratio of attachment height to height of structure plays a role in the overall resultant seismic force using ASCE 7-10 Eqn 13.3-1.
However, I'm not sure the Z and h values are entirely representative of the situation here. Maybe I can't or shouldn't even really use this calculation.
Should I use this section?
If so, how should I resolve the z and h ratio? z/h=1.0 for ceiling mounted equipment seems a bit much considering this entire thing is below grade.
