dursunlutfu
Hi Folks,
My question is about the lateral distribution of seismic force for a 2-story wood framed residential building.
Info about the building : The front portion of the ground floor has a roof at a level which is almost 2 feet higher than the second flor of the house. I am planning on dragging the roof diaphragm of the front portion of the ground floor to the 2nd floor diaphragm at N-S Direction. At E-W direction there are walls which can be used as shear walls for the roof diaphragm at the front portion of the building. So when calculating the total weight of the building, I am planning on including the load of the roof of the front portion of the ground floor to the second floor but here when everything gets tricky. I am also planning on finding the seismic force at E-W direction for the roof of the front portion of the ground floor by only including the weight of the roof and the base shear of the house.
I am wondering if this approach is logical or not and I am wondering if you guys have encountered a situation like that ..
Is there a specific reference for this type of an issue ?
Thanks !!
Thanks !!
