sam4106
- Sep 8, 2017
- 1
I have a moment frame structure divided by expansion joints. I've sized the required structural separation and have provided this information to the architects for expansion joint cover selection. They've asked me to clarify the movement criteria needed to select an assembly.
For example, if the maximum inelastic displacement for both structures is 3.5", SRSS says I need a 5" joint. The architects chose an assembly accordingly but the minimum opening size listed on the products performance data is 1.00". So, 5" - 1" = 4"/2 = 2". This doesn't accommodate the two structures moving 2.5" towards each other and definitely not 3.5".
So, how are we to understand what the SRSS method is telling us regarding the direction and magnitude of movement for two adjacent structures? Additionally, does the expansion joint assembly need to be sized to accommodate that total movement? Since the assembly is non-structural and we expect inelastic behavior during an earthquake, is damage to that component acceptable?
Thanks in advance!
Thanks in advance!
