Hello dear colleges, .
I am trying to achieve differential protection on a transformer using a SEL-387E but the LV CT will have to be shared through the downstream overcurrent protection (SEL-351S) due to lack of CTs.
The star point of the SEL-351S prot, is loooking away from the TX. So, my question is, If any one know if it would be an issue to reverse the starpoint of this CT ? Since the SEL-351S is only doing 50/51? Is there settings changes due to this? (It would be looking away from the Line)
or if it is possible for the SEL-387E to reverse the element wiring or if this can be done through settings for the LV CT.?
thanks for the insight, my expertise on what these relays can do through settings is limited.
