select geometrical set without click 1
RubenSilva
PT
Hello
i have a macro that every time i run i have to selelct the geometrical set, but its always the same
I use this code to select the Geometrical Set:
Code:
Status = MySelection.SelectElement2(vFilter, "Select Geometrical Set", True)
There are another way to use always the same Geometrical Set without clicking there? Just pre-define on the code what is the Geometrical Set
Ruben
if your GeoSet is right under Part then it is just one HybridBodies level, otherwise you will have to "dig down" to the correct level...
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim MySelection As Selection
Set MySelection = partDocument1.Selection
Dim part1 As part
Set part1 = partDocument1.part
Dim myHBody As HybridBody
Set myHBody = part1.HybridBodies.Item("inWork")
MySelection.Add myHBody
regards,
LWolf
