Hi, as linked paper suggests advanced material property is required to simulate 3d-printed parts under pressure(+/-).
to clarify it suggests making tensile samples in vertical , flat , on edge , and 10 degrees (for shear prop.) positions. i did make similar samples plus a compression saplme and i did run standard tests now, how do i can insert these data in Abaqus properly?
