I usually use AISC's Design Guide 1 to design base plates. This design guide doesn't consider the case of stiffened base plates nor consider the possility of semirigid connection (At least the version that i have). Recently, i started using Idea Statica's stiffness analysis module and saw that a lot of unstiffened base plates calculated to support bending moments fall into semirigid connection category, according to Eurocode, and the stiffness diagram is nonlinear.
My question is: Do you guys usually compute the stiffness of the base plates and input in the model to increase accuracy?
Since the Stiffness diagram is nonlinear, due to the nonlinear behaviour of the concrete, the secant stiffness at 2/3 M[sub]j,Rd[/sub] defined in Eurocode is overly conservative and any software which doesn't have the capability to consider the nonlinear stiffness will give excessive deflections.
