sensor
anto84
5
hi..
Anyone knows which kind of sensor is it?
you see attachment
Vorrei sapere se si tratta di un sensore di misurazione termico in ambiente esterno o interno o entrambi; per aria, acqua, suolo ... e il suo marchio (se si conosce), e come funziona..
thank you
Antonio.
 http://files.engineering.com/getfile.aspx?folder=24061f3d-3970-47e8-86a6-400e80b32695&file=20141009_120513.jpg
hi..
you see attachment
I would like to know if it is a sensor measuring the thermal environment in the external or internal or both; for air, water, soil ... and its brand (if you know), and how it works ..
thank you
Antonio.
 http://files.engineering.com/getfile.aspx?folder=c81f2e51-8a91-4d80-a471-436b1fd25bc2&file=20141009_120513.jpg
Looks like the temp sensor for my oven at home-the connector plugs into the oven wall, and the tip jabs into meat.
