bacon4life
Is there any way to estimate the sequence impedances for the Wye-Delta-Wye 12.47 kV/480V transformer in the attached image? I am trying to calculate how high I should set the ground fault relaying at the substation to avoid tripping on a feeder that has several similar Wye-Delta-Wye distribution transformers. On transmission transformers with tertiaries the impedance varies over a large range, but am hoping maybe the impedances are more consistent for distribution transformers. I tried contacting the manufacturer, but they do not have the sequence impedances available.
