I've been around a few months now and this is my first question for you guys. With all the extra time I have in home, I thought I could use your expertise and clear some old topics I've been struggling with now and then.
I'm somewhat familiar with the concept of series transformers when it comes to the typical connection (see A below), with a regulating winding of a main unit feeding the primary of the series transformer and its secondary connected in series with the secondary of the main to increase or decrease its final secondary voltage (Us).
That's not the problem.
The problem for me begins when you consider a different arrangement, with the series transformer connected on the primary side (like B below). This circuit is not discussed in any book I've checked, and I've always thought that it wouldn't even work!
To be more clear, the typical circuit assumes that the primary voltage (Up) is constant and you regulate the secondary (Us) (usual IEEE approach) and the alternative B was considered for regulating the primary voltage so the secondary remains constant (like IEC approach).
-Sorry for the messy sketch, some details were omitted or forgotten for more clarity-
So far so good, I was sure that this contraption didn't work and I was happy to defend my views on the subject, always as a theoretical exercise.
Now the problem: a few years ago I stumbled across a "living proof" that I was wrong all along and indeed this kind of circuit B existed and was used at least on one power transformer.
My question is: if this circuit B works, how??? I mean the concept behind it. I can't wrap my head around it.
