I admit I am a bit stumped. Probably not enough coffee yet!
I am working on a part that has a serrated end (DIN serration). The other end of the shaft has two flats milled on opposite sides of the shaft (flats are parallel).
The issue at hand is that the serration needs to be oriented WRT the flats.
My initial thought is to define the diameter of the part as primary datum A. Secondary datum B to be defined inline with the dimension across the flats. I think this sets up the datums in this particular case according to our requirements.
Currently my theory is to use angularity WRT A and B and the first space in the serration (not sure if my description makes sense). Not great and maybe dead wrong but I have a major GD&T brain block right now.
I don't have a copy of ASME Y14.7.1 or Y14.7.2 so I am not sure if there is information in these standards that might apply. If anyone has experience with these standards and this is covered I will rush out and nab them but I don't want to purchase them if they don't apply. I am reasonably sure they do not apply to the specification of the DIN serration but perhaps somewhere in one of the standards orientation of splines is discussed??
Any help/guidance would be appreciated. Thanks!!
