Just like you would any other electronic device in the space, only on steroids; it is 10 tons of sensible load.
Most server rooms I've seen and designed will have their own air conditioning units which are frequently located in the server rooms themselves. Commonly called CRAC (Computer Room Air conditioning) units, they are not designed for lots of ventilation air. Having a dedicated AC for server rooms allows them to be run 24/7 while HVAC for the rest of the building goes between occupied and unoccupied modes constantly resetting temperature set points.
When you do your air distribution layout, put diffusers around the perimeter of the racks or above aisles; locate return air grilles above the racks. This will help to keep the environment in the room more comfortable for the technicians.
Redundancy is highly recommended, how much is a conversation to be had with the client. Typically I've seen 2 units at 2/3 total capacity for the space. More units means smaller units. There is no code or guide that I'm aware of dictating how much AC redundancy to install, it will depend on available space and how valuable the servers are to the client.
