Nasim12345
Industrial
- Apr 25, 2017
- 53
Dears
While testing the PSVs, we are following the set pressure tolerance based on below ((ASME Section 8, UG-134 D (1))
The set pressure tolerance for pressure relief valves shall not exceed ±2 psi (15 kPa) for pressures up to and including 70 psi (500 kPa) and ±3% for pressures above 70 psi (500 kPa), except as covered in (2) below.
What is the meaning of 2nd statement from ASME Section 8, UG-134 D.10% Tolerance is mentioned in below statement. (ASME Section 8, UG-134 D (2))
"The set pressure tolerance of pressure relief valves which comply with UG-125(c)(3) shall be within −0%, +10%.".
Find attached snapshot from ASME. My query is about 10% tolerance.
Nasim
Nasim
