Settlement of SS Pipe to Sleeper
jafary64
17
Hi
we have Stainless steel Pipe that should be rest on Sleeper due to Galvanic corrosion it doesn't contact between Embedded plate on sleeper & SS pipe
now I want know we should use shoe support or can use SS plate over of Embedded plate to prevent Corrosion
Thanks a lot
You can use a standard shoe support, but make sure you have an insulating barrier between pipe and shoe, like PTFE or neoprene.
Shoes are a normal solution for this, especially if your pipe is insulated. Similarly, you can just rest the pipe on a non-metallic pad. There are even some load rated products for this like I-rods which you can buy by NPS, height, etc.
