In our Ammonia plant CO2 removal section , one of the hardest to deal with problem has become the necessity to continuously and in batches inject antifoam for the following reasons:
The Urea Plant downstream , which uses the CO2 from the CO2 stripper, has the problem of increasing temperatures in their reactor which converts hydrogen to water , in an endothermic reaction . the urea plant has limitations on their temperature increase. Somehow by injecting antifoam to the Absorber The temperature in their reactor is decreased for a short period of time ?(around 2 hour) .
by the time the Urea reactor temperature increases the gas flow from HP flash vessel to flare is also increased ,causing the pressure control valve MV to open more .
CO2 removal system is aligned as Absorber >HP FLASH VESSEL > STRIPPER
What effect does antifoam have on Hydrogen leakage to CO2 stream above stripper column?
