moiz19670309
What is the general rules for shaft and impeller fit. I have a straight shaft who's outer measured diameter is 97.4 mm. The shaft has a key 12 mm key way. At this dia a impeller fit on the shaft with this key. I don't have the hole dia of impeller.
I want to make a new shaft. What dia and tolerance I should apply on the shaft to have the impeller seated in.
Any helpful document or table please.
Moiz Khan
Moiz Khan
