I have a shaft connected to a piece of equipment, with a protective covering welded between the piece of equipment and the shaft to protect the hardware the shaft is attached to the piece of equipment with from corrosion. As the equipment rotates, the shaft bends, pulling on the boot and eventually the weld between the boot and the shaft ends up cracking. Running an FEA on the boot, and we see the highest von mises stresses on the sides of the boot, where the boot/weld would be mostly in shear. Since it's shear, there is no negative value associated with it like there is with tensile stress, but its happening in opposite directions on the left and right side of the boot, so, should I evaluate the stress as cycling from X psi to -X psi, or from X psi to Y psi (where Y is some lower, non-negative value)?
