jd1rose
- Nov 16, 2006
- 6
I need some control circuit help. I have a shaker for scrap that is used on all of our press lines. I need to detect when the shaker stops for a malfunction. I want to hook up a prox sensor that is stationary and a bracket that will move with ths shaker in and out. So it will make and break the prox sensor. If this signal stops for more then 1 minute I want it to stop the press line with a e-stop fault.I need help to come up with the hardware to create the logic.
Roy.
Roy.
