Shape search
rokwelll
3
Hello, i want ot make active shape search command but i cant this.Says in the help menu,
1-GEOLUS_HOME= ?
2-GEOLUS_JAVA_HOME=?
best regards
"Shape Search" is far far more difficult to install & setup than simply setting a couple of env variables.
Did you installed Geolus Search before?
regards,
Beppe.-
Beppe Grimaldi
SISW Italy
Thanks Beppe , I wanted to use this command but I dont have enough information about shape search and geolus search.I will investigate this issue.
best regards
?ahin
Geolus is a seperate application which "bolts on" to the main system. Siemens acquired it from a company who were already selling it as a standalone system and made it fit with NX/TCEng. You will need to buy a licence which will cost you a fair amount.
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
Thanks Simon , i'll talk to our software consultant about geolus search.
Best regards
?ahin
I can recommend another system which is far better and 10 times cheaper than Geolus, we are looking at taking it on here at the company I work for. Click the link
Best regards
