hi all, I'm wondering if ACI design code shear strength is based on elastic or plastic?
I try to make an Abaqus model of a shear pry-out/breakout and compared it to result obtain in ACI design code.
the result shown in the attachment where the elastic can be seen stop around 11-12ton which is similar to the result obtained in ACI design code then it continues its plastic till 16-17 ton.
from this result does it mean ACI design code strength is only elastic strength?
but I have a feeling that it should be plastic since it's a pry-out and breakout case where it's a behavior happen when the concrete already totally fails?
so, I became not sure either my Abaqus model is right or wrong....
