Suthees
- Dec 26, 2018
- 1
1) In Base plate Design, Shear capacity needs to be reduced by 20%(because of bolt bending) as per ACI 318-02 if grout pad is used
And AISC SDG 1 p.29 specifies Based on shear friction theory, no bending of the anchor rod within the grout need be considered.
Please clarify
2) Is there any change in the shear capacity of bolts if the base plate embedded in concrete/ concrete screed .
MKS
Please clarify
MKS
