ks11
- Mar 5, 2019
- 5
Hello, I'm looking for resources on how to determine fatigue life of the threads in a joint under cyclical loading. I have a grade 8 1 1/4-7 cap screw clamping two pieces of 304L, with the second piece of 304L being tapped to hold the cap screw. The cap screw has a preload of about 24% of its yield strength, which for the size of material and depth of threads I have calculated the internal (304L) threads to have a safety factor of 1.12 under the maximum load they will see as a static case, but the loading is cyclical and I am having a hard time finding information about how to look at such a case. Most of what I have seen fatigue wise assumes the bolt and clamped material are the same material or looks only at the bolt as a failure point. I have a seen it mentioned a few places that fatigue failure in shear is very rare, though I'm not sure why that would be the case or if I misunderstood what that statement was being applied to. I also understand the first thread in the joint is typically carrying the largest portion of the load, some 30-40% which decreases somewhat when the internal thread is a softer material and the threads yield to more evenly distribute the stress across multiple threads. Can anybody point me in the right direction or clear up some of the things I am misunderstanding? Thank you in advance.
