BendingMoment123
- Apr 1, 2020
- 25
Hi guys
I have beam (beam 2) bolted to the underside of beam 1. Beam 1 is welded to a 30 mm plate which has 10 bolts (5 on either side) anchored into the rock above. The shear fore (V) is eccentric to the centroid of the bolt group, so it would put some bolts in tension. But i'm not worried about that, as the axial force (C) is a very large compressive force.
- Is it safe to assume that force V can be distributed equally among the 10 bolts (V/10)? All bolts and holes are the same size.
- What dispersion angle would you assume for the axial force (45 degrees?)
