Hey everyone, I'm trying to get a gut feel for amount of shear studs (stud pattern) etc cause I have never had to design them. Situation is: 3.5" overall thickness composite decking with light weight concrete; joist are spaced every 4ft. The goal is to get the shear into the joists to transfer it into the building framing down to foundation. I can't seem to find a typical pattern or layout for shear studs. I came up with 3/4" studs at 2ft on center at ever joist. I then had someone recommended I add them in between joists every 16" on center (so instead of 1 row every 4ft at the just the joists there would be 1 row every 16") and that just seems like overkill.
What have you guys seen as typical?
Thanks in advance!
Thanks in advance!
