Great Lake
- Nov 10, 2024
- 8
Hi, I have several questions,
1. Let say, for shear wall sticks out on certain levels and recesses on other levels in high-rise building. When you model the shear wall, will you only model the shear wall for the common portion straight up from basement to top level?
2. If the building comes with basement and superstructure, will you model the whole structure once or do 2 models, one for structure from ground level to the top level (of course the ground level must be rigid enough) and the other model only including basement and the shear wall force taken for the first model imposing as loading?May I know the popular software to analysis the shear wall structure in Canada?
3. For transfer slab or beam on second level, will they be include in Etabs model? or you use Safe? if using Safe, how you will get the loading? Can someone brief me?
4. For seismic design, the seismic loading is imposed on ground level or basement level? "Construction Design Handbook" mentions that the loading imposed on basement level, I want to confirm.
5. Thanks for your attention.
