I am trying to reproduce a shell bolt model like the one in "A global bolted joint model for finite element analysis of load distributions in multi-bolt composite joints".
This may be a similar question as the one in but I still haven't found a solution. The paper mentions a contact tolerance of 10um, and clearance (but using finite sliding), so I can't fully understand what they meant and what options they used.
Additionally, the model runs just fine (although the solution is wrong, probably due to the contact definition and clearance) in a linear analysis. When nonlinearity is on, a bunch of negative eigenvalue warnings appear, but I can't seem to get rid of them.
Has anyone been successful in modelling anything like this?
Thank you!
Thank you!
