Ravichandra veluri
I continuously reading that every shell element has 6 DOF in program. How ti check these 6 DOF in analysis
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The Shell element always activates all six degrees of freedom at each of its connected
joints. When the element is used as a pure membrane, you must en sure that
restraints or other sup ports are provided to the degrees of freedom for normal translation
and bending rotations. When the element is used as a pure plate, you must ensure
that restraints or other sup ports are provided to the degrees of freedom for in-
plane translations and the rotation about the normal.
The use of the full shell behavior (membrane plus plate) is rec om mended for all
three- dimensional structures.
Note that the “drilling” degree of freedom (rotation about the normal) is not used
for the layered shell and should not be loaded.
