cak4Engg
Petroleum
- Jun 13, 2015
- 19
Dear All,
In a heat exchanger, in order to keep the exchanger height as min. as possible, I have proposed the following config.
Where the Shell course (Item-01) with a UG-34(f) flat head (Item-02) is extended and the base plate(Item-03) is welded to it.
one of my colleagues has a comment that Since this joint configuration is nowhere addressed in the code, we need to perform FEA as per u2(g) evaluate the said configuration.
What do you guys think about this, is it acceptable as per code? do we have to perform FEA?
I would really appreciate your input.
with regards
with regards
