shell181
AIDIN002
3
Hey Guys
I am beginner in APDL. I want to use shell 181 to mesh a thin plate. what is different between real constant and section?
Both have parameters for defining thickness and mass? so, which one I use ? what are differences?
thanks in advance
There are no real constants defined for SHELL181, so you must use a section.
Rick Fischer
Principal Engineer
Argonne National Laboratory
Thanks rickfischer51
Actually you are right about pre-processor tabs. But It is possible to add rc for shell181 by r command,I solved a thin plate by r command.My question is what is benefit of rc?
Thanks for your attention rick.
There is nothing in the manual regarding real constants for SHELL181. I still have V14.5 installed, nothing there either. My guess is the element was created with a real constant thickness, and that feature has been undocumented in favor of sections. If it still works, I guess its OK to use. One thing I've run into is the emodif command does not work to alter any attributes via the section method.
Rick Fischer
Principal Engineer
I use V18 and , here there is nothing in manual about realconstant too, but in macro line r command works!
Anyway,can I know what is your trouble with emodif,and what was your example? I wonder when this command is useful?
Thanks Rick
