johnny1112
I just want to ask if you encounter this problem at short circuit analysis using etap? I have change the Tkr of the breaker from the original of 1 to 3. the rating limit from 25-75 Mj but the operating also increases from 37.089-99.347. vice versa when I lower the Tkr I still have this problem. Also When I change the amp rating of the cb it is still the same. What can I do to solve this problem?
Thank you!
Thank you!
