Shortcut key to insert a row in a tabular note
Befuddled
Aerospace
Jan 9, 2008
68
0
0
GB
Hi All,
Is there a keyboard shortcut to insert a new row in a tabular note?
I am currently using a drawing template which only has 1 blank line by default when its inserted, so find myself having to manually MB3 > Insert > Row Above(which is a bit tedious)
I sure there used to be (that, or i'm mixing up my cad systems)
using NX1973.
Thanks in advance,
Cheers,
B
1.You click RMB on empty places of any galeries (Home, Layout, etc.) and select Customize (last position on list).
2. After select "Keyboard"
3. In left-top window select: Edit-Table-Insert-Row-Below (or Above).
4. Stay in bar Press new shortcut key and Press Your combination of Keys (if You need it only in current application change Global to Application Only).
5. Press Assign
6. close all windows and work with new shortcut key.
One information - if You select more then one rows and click insertRow-Below - program add the same number of rows as You selected.
Best regards
MANok
NX2027
TC14
